Gandalph Posted January 24, 2006 Author Report Share Posted January 24, 2006 Having problems installing that one Thos for some reason. I've downloaded and removed it and downloaded it for the fourth time and it still refuses to load.Anyone got any further suggestions. :huh: Quote Link to comment Share on other sites More sharing options...
doug Posted January 25, 2006 Report Share Posted January 25, 2006 Just downloaded it. Seems to work so far. Quote Link to comment Share on other sites More sharing options...
Gandalph Posted January 25, 2006 Author Report Share Posted January 25, 2006 Just downloaded it. Seems to work so far.Could be something at my end Doug. Will give it another bash and see how it goes. Quote Link to comment Share on other sites More sharing options...
rong Posted January 25, 2006 Report Share Posted January 25, 2006 Just downloaded it not a problem, I now hope it comes off easily Quote Link to comment Share on other sites More sharing options...
Gandalph Posted January 25, 2006 Author Report Share Posted January 25, 2006 Just downloaded it not a problem, I now hope it comes off easilyShould do rong. I removed mine useing the add/remove in Control Panel. Quote Link to comment Share on other sites More sharing options...
andsome Posted January 25, 2006 Report Share Posted January 25, 2006 I always play safe and do a search for files in Windows Explorer, and delete them. Then run CC and RegScrub XP, and finally export and save the registry and delete any bits and pieces in there. It's possible that if your first install was corrupted, that only this treatment will sort things out for a good install. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 25, 2006 Report Share Posted January 25, 2006 HiI have been useing Net Meter from here http://readerror.gmxhome.de/ for the last couple of year, it is good.It gives you Hourly, Daily, Weekly, Monthly & Yearly usage figuresTony. Quote Link to comment Share on other sites More sharing options...
catgate Posted January 25, 2006 Report Share Posted January 25, 2006 Having problems installing that one Thos for some reason. I've downloaded and removed it and downloaded it for the fourth time and it still refuses to load.Anyone got any further suggestions. :huh:I downloaded it and installed it last night (Tues) and it worked fine. It seems to verify pops' original reassurance.(Incidentally thanks for the info, Thos.) Quote Link to comment Share on other sites More sharing options...
Gandalph Posted January 25, 2006 Author Report Share Posted January 25, 2006 I always play safe and do a search for files in Windows Explorer, and delete them. Then run CC and RegScrub XP, and finally export and save the registry and delete any bits and pieces in there. It's possible that if your first install was corrupted, that only this treatment will sort things out for a good install.Likewise andsome. I never trust add/remove to completely remove a programme. I always use the same system as you as guaranteed there will be something left behind.I've got the programme up and running at last. I don't know what was stopping it before but it's certainly doing the stuff now.Only one question for those that know the programme. In settings does the Monthly roll-over number mean the date the current monthly cap ends. I've set it to 23rd as that will be exactly one month from the day I was connected to BB.Tony, many thanks for that link. Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted January 25, 2006 Report Share Posted January 25, 2006 I've set it to 23rd as that will be exactly one month from the day I was connected to BB.I'm glad you finally took the plunge and decided to upgrade to broadband and I think that you will agree that it is a definite improvement! Quote Link to comment Share on other sites More sharing options...
