Must Build SuperComputer
playaj20008
I can't believe this is serious.
If you held a position in a company of sufficient importance to have this request made of you then you would already have sufficient knowledge and expertise not to require the input of a forum like this which, after all, comprises part time volunteers and amateurs - even though they may be enthusiasts.
It also doesn't tie up with your claims in another thread http://forums.windowsforum.org/index.php?s...c=27777&hl= in which you are a 16 year old student.
  • 3 weeks later...
Umm how about screw both of you. Yes I am 16. No I wasn't hired specifically to build this computer, but me being the most tech savvy guy at my company was selected for the task. I'm sure I could look around and throw together the fastest parts I can find but I'm looking to go over the top, so either help me out or eat my a$$.
I will not accept that sort of attitude or language towards any members of this forum, this thread is now locked.
If your company is giving you that much money to spend to build some super computers I suggest you spend some of it on some consulting expertise
