I keep getting a blue screen on my computer and I dont know why... I really need help in solving these crashes, as my screen name is SO true. Im trying to attach the two critical errors that I see in the event viewer and also trying to attach the actual blue screen that I am getting. Thx in advance post-23833-0-28809000-1352941286_thumb.j
- System
- Provider
[ Name] Microsoft-Windows-DriverFrameworks-UserMode [ Guid] {2E35AAEB-857F-4BEB-A418-2E6C0E54D988} EventID 10110 Version 1 Level 1 Task 64 Opcode 0 Keywords 0x2000000000000000 - TimeCreated
[ SystemTime] 2012-11-09T22:45:51.802118200Z EventRecordID 93306 Correlation - Execution
[ ProcessID] 1048 [ ThreadID] 1352 Channel System Computer Lynn - Security
[ UserID] S-1-5-18 - UserData
- UMDFHostProblem
[ lifetime] {AA851468-40FE-4D3B-84D8-E82FEA3A50D9} - Problem
[ code] 3 [ detectedBy] 2 ExitCode 3 - Operation
[ code] 259 Message 4 Status 3221225653
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power [ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4} EventID 41 Version 2 Level 1 Task 63 Opcode 0 Keywords 0x8000000000000002 - TimeCreated
[ SystemTime] 2012-11-14T21:43:41.044020200Z EventRecordID 104592 Correlation - Execution
[ ProcessID] 4 [ ThreadID] 8 Channel System Computer Lynn - Security
[ UserID] S-1-5-18 - EventData
BugcheckCode 209 BugcheckParameter1 0x28 BugcheckParameter2 0x2 BugcheckParameter3 0x0 BugcheckParameter4 0xfffff880019046fd SleepInProgress false PowerButtonTimestamp 0
Link to post
Welcome to the Windows Forum!
First, what Windows version are you using?
Unfortunately the picture you took of the BSOD is not showing all information; the driver name near the bottom is incomplete - I can only see 'ETIO.SYS'. Can you tell us what the full name is of that module?
Most likely you need to update a device driver, but we can only tell you which one if we know the full name of that module.
Link to post
Thanks for the response... I use windows 7 Home Premium (service pack 1)
I use Microsoft Security Essentials as of right now, but on this pc I have used Norton, McAfee & AVG.
Display Adapter: Mobile Intel® 4 Series Express Chipset Family
Im HAVE NO IDEA about the device driver version & date.... Is there anyway you can put it in laymen's terms for me???
I do have a ntbtlog.txt if that might help. Its really long and i dont know how to read it. I think it might logged more than one crash on it, not sure if it can actually do that or not.
Link to post
