tony-fr-si Posted November 10, 2005 Report Share Posted November 10, 2005 Version IV (4.11) The Savings Bond Wizard ® helps you manage your savings bond inventory on your PC. It's a downloadable program that allows you to maintain an inventory of your bonds and determine the current redemption value, earned interest, and other information. You can also print your bond inventory, providing you with an important record if you ever need to replace any of your savings bonds. Savings Bond Wizard is a registered trademark of the U.S. Department of the Treasury, Bureau of the Public Debt. Windows is a registered trademark of Microsoft. [b]http://www.publicdebt.treas.gov/sav/savwizar.htm -------------------------------------------------------------------------------------------------------------------------Here's my problem! Prior to installing verizon dsl, I was able to automatically run updates to the bond files from either of the two accounts I have setup as ADMISTRATOR types under windows xp/pro. Now I can only run the auto updates from only one of the ADM type accounts. It's always the same one that fails.I unistalled the software and reinstalled to no avail. Problem still there. Can only update from one of the ADM type account. DSL provider says its not their problem. Any help out there???????Will provide additional info if requested. Quote Link to comment Share on other sites More sharing options...
tony-fr-si Posted November 10, 2005 Author Report Share Posted November 10, 2005 Version IV (4.11) The Savings Bond Wizard ® helps you manage your savings bond inventory on your PC. It's a downloadable program that allows you to maintain an inventory of your bonds and determine the current redemption value, earned interest, and other information. You can also print your bond inventory, providing you with an important record if you ever need to replace any of your savings bonds. Savings Bond Wizard is a registered trademark of the U.S. Department of the Treasury, Bureau of the Public Debt. Windows is a registered trademark of Microsoft. [b]http://www.publicdebt.treas.gov/sav/savwizar.htm -------------------------------------------------------------------------------------------------------------------------Here's my problem! Prior to installing verizon dsl, I was able to automatically run updates to the bond files from either of the two accounts I have setup as ADMISTRATOR types under windows xp/pro. Now I can only run the auto updates from only one of the ADM type accounts. It's always the same one that fails.I unistalled the software and reinstalled to no avail. Problem still there. Can only update from one of the ADM type account. DSL provider says its not their problem. Any help out there???????Will provide additional info if requested. Quote Link to comment Share on other sites More sharing options...
tony-fr-si Posted November 13, 2005 Author Report Share Posted November 13, 2005 The problem is user related software. When running from another account you must right clight on the icon and click on the "run as" option. It then prompts yopu to enter the primary user account name and password. After entering it, it then can run in that specific user account. :) Quote Link to comment Share on other sites More sharing options...
