Guest Nellie2 Posted March 1, 2003 Report Share Posted March 1, 2003 I seem to have acquired a little problem which, although it isn't drastic, is driving me slightly nutty.Windows 98 SE.......I seem to have lost the file association for all my JPEGS and GIFs. When I go into the files where they are stored all I see are those little window pictures. Usually when you try to open one of these you get a box pop up asking which program you want to use to open the file......but when I double click on them nothing happens and when I right click on them I am not getting the option to 'open' or 'open with'.However....... I do get the preview when I click on them and I can open up paintshop and then open my pictures using the program that way.The only thing I have installed or uninstalled recently is Outlook....went on then came off and Eudora......that went on and came off too. Neither of them took any shared thingies with them when they went as far as I know.Any ideas....... I don't want to fiddle any more in case I make an annoying situation into a bad one.....thought I would see what you come up with.Oh, I have run SFC.....no probs there!!! Quote Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted March 1, 2003 Report Share Posted March 1, 2003 try pressing shift+right clicking the file, then you get the open with option Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted March 1, 2003 Report Share Posted March 1, 2003 No I don't.......... I get View, customise this folder, arrange icons etc....... :( Quote Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted March 1, 2003 Report Share Posted March 1, 2003 that happens when you right click inside the folder, i'm asking you to press shift and simultaneously right click on the jpeg or gif file itself. Quote Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted March 1, 2003 Report Share Posted March 1, 2003 if thats what you did and it didn't work then i'm out of my depth here :( Quote Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted March 1, 2003 Report Share Posted March 1, 2003 you could try going to folder option in control panel and going to the file types tab , scroll down till you get to jpeg (or click the 1st file type and press jpeg on your keyboard) and edit the properties thereunder the 'open with' section you can click change and specify a program so that from now on all jpegs will open with that particular program you choose Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted March 1, 2003 Report Share Posted March 1, 2003 i'm asking you to press shift and simultaneously right click on the jpeg or gif file itself.That is what I did!!!!I don't seem to have a folder option in Control Panel........ :( Will be back later........visitors!! I am supposed to be making a cup of tea now!!!! Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted March 1, 2003 Report Share Posted March 1, 2003 A bit of an update....... I was in my folder again and I selected the image with a left click and then I right clicked and shifted and I got the option this time...to open with!!!!I have associated everything with MS photo ed for the time being. Paintshop Pro wasn't on the list, must have gone for a holiday which is where the prob came from I expect.......will look at that later!!!!Thanks for the help and sorry for being a bit dim!!!!! :) Quote Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted March 1, 2003 Report Share Posted March 1, 2003 lol glad everything got sorted out havn't used 98 in more than 2 years so was struggling and working from memory :) Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted March 1, 2003 Report Share Posted March 1, 2003 Well.........'tis much appreciated. Thanks once again for the help Quote Link to comment Share on other sites More sharing options...
