moon Posted August 7, 2004 Report Share Posted August 7, 2004 The delays might make life easier for businesses and home users alike, if the hardware manufacturers heed Microsoft's call to work on 64-bit drivers. Although 32-bit software runs happily, 32-bit drivers don't, because it's too dangerous to run anything in the kernel that's not completely compatible with the hardware. That means anything you connect to your system, from a network card to a digital camera, will need a new driver. http://www.guardian.co.uk/online/story/0,3...1275827,00.htmlI'm not quite sure what this gal is saying. Am I to read that as 32bit drivers don't function properly with the current 64bit cpu's available ?Edit; And this doesn't look good; To put it crudely, the hardware manufacturers already have your money, so why should they produce new drivers for new versions of Windows so you can run old devices? Quote Link to comment Share on other sites More sharing options...
