peter e Posted March 23, 2003 Report Share Posted March 23, 2003 Hi all. ;) I've been making some changes to my site, one of which is to add a links page. As you may know, I use frames and each tutorial page opens in the main frame. However, I've added a links page which opens in the main frame (which is OK) but clicking on a link opens that page in the same frame and I want it to open the link in a new window. I don't know how to do it in MS Word. I've been messing around for ages but I still can't discover how to do it. Anyone have any ideas?Here's the link to My Site.Thanks :D Pete Quote Link to comment Share on other sites More sharing options...
Guest Damo Posted March 23, 2003 Report Share Posted March 23, 2003 IM not to sure about Using Word pete but, when you set up the hyperlink, the Target needs to be set to _blank like i say, im not to sure where it is in word (i dont have it on this pc) but look out for 'Target'Maybe Madboy can helpDamo Quote Link to comment Share on other sites More sharing options...
Guest Damo Posted March 23, 2003 Report Share Posted March 23, 2003 Just dug out the HTML from my site.......this is what it should look like....just add the target="_blank"< a href="http://www.windowsforum.org/forum" target="_blank" >Ive added a few spaces between the < and >CheersDamo Quote Link to comment Share on other sites More sharing options...
peter e Posted March 23, 2003 Author Report Share Posted March 23, 2003 Thanks, Damo. I'll try it out tomorrow. Haven't got time now - got to go soon. I've been looking at the HTML code that Word writes and I've found the bit pointing to the web addresses so maybe it's just a matter of adding the "_blank" bit.Word makes it easy to add hyperlinks and set pages to open in the frames. But no matter what I try, there seems no easy way to have the actual links open in a new window if the links page is in a frame. Perhaps I'm missing something. As I say, I'll try your bit of code and see if that does it.Thanks again, Damo. ;) Quote Link to comment Share on other sites More sharing options...
Guest Damo Posted March 23, 2003 Report Share Posted March 23, 2003 add............target="_blank" to the same place where mine is.....ie just after the link destination.....dont forget the 'target' bit aswell.Im sure theres an easier way of doing it in word without having to edit the code, but im unfamilier with word.PS the sites looking good mate!Damo Quote Link to comment Share on other sites More sharing options...
madboy33 Posted March 23, 2003 Report Share Posted March 23, 2003 thats the code you need there mate Quote Link to comment Share on other sites More sharing options...
madboy33 Posted March 23, 2003 Report Share Posted March 23, 2003 PeteMy Mother-In-LawLooked at your site and thinks its really good as she has not got a clue about e-mail and outlook expressCheers mate for that as she does not phone me every ten minutes madboy33 Quote Link to comment Share on other sites More sharing options...
Guest whizwrinkly Posted March 24, 2003 Report Share Posted March 24, 2003 There is also a bit of java script you can add to open a new window of a specified size. If you check out one of the photo pages on my site you will see what I mean.If you want the code email me and I'll send a full explanation of how to use it. (Too knackered to do it now!)Cheers, whiz... :sleep Quote Link to comment Share on other sites More sharing options...
peter e Posted March 24, 2003 Author Report Share Posted March 24, 2003 Thanks again for the code, Damo. I've sent you a PM. Oh! I've just got your reply - thanks.Glad your Mum-in-law is happy, Tony. I'll do a site about using MSN Messenger with web cams for her next - and then you won't be able to pull funny faces as you speak to her. LOL.Thanks, Whiz. I'll look at your site. That bit of code should come in handy - I'll be in touch.I hope to finish my site within the next couple of weeks (there's always something else to do - like go to work).Thanks again for the assistance and positive comments. ;) Pete(I will more than likely need your help again :blink: ). Quote Link to comment Share on other sites More sharing options...
madboy33 Posted March 24, 2003 Report Share Posted March 24, 2003 ask away matewe are allways here to helpmadboy33 Quote Link to comment Share on other sites More sharing options...
peter e Posted March 24, 2003 Author Report Share Posted March 24, 2003 For information. I've uploaded the links page and they all open in a new window thanks to Damo's help. Any suggestions for further relevant links to add are most welcome (not you, ellas. I know what sort of links you will suggest :D lol).Thanks again everyone. ;) PeteMy Site Quote Link to comment Share on other sites More sharing options...
