edmccrory Posted February 3, 2005 Report Share Posted February 3, 2005 Here is a simple one, but since I don't understand all I should know about networks, I need help.I am trying to set up forwarding on a Belkin wireless router attached with a DSL Internet connection to a computer which will be acessed as a remote.The master computer uses an identical setup.I have followed the instructions for the Belkin rounter forwarding setup but obviously do not have the proper IP address for the remote. I used the private IP which the router assigns to the computer.What should the IP address be that will allow access to the computer through the router firewall?Thanks for your helpEd Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted February 3, 2005 Report Share Posted February 3, 2005 You'll have to tell the Router(s) about the Routers outside (Internet) IP's. It will be a valid Internet Address. Internal addresses won't work in the configuration you're using. Please let me know if you need any clarification. :) Quote Link to comment Share on other sites More sharing options...
edmccrory Posted February 3, 2005 Author Report Share Posted February 3, 2005 Clarification please - are you saying that the router's address (outside the connecting machine) would be listed in the forwarding table?Thanks for your quick reply Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted February 3, 2005 Report Share Posted February 3, 2005 Edmccrory,The router has an inside and an outside interface.LAN :) Quote Link to comment Share on other sites More sharing options...
edmccrory Posted February 3, 2005 Author Report Share Posted February 3, 2005 Ted, thanks very much for the clarification - this is clear and I understand what you are saying. The only problem that I see now is that I have used the Gateway address in the virtual server setup for the Belkin router and it didn't work. I will go though the process again just to make sure.Thanks for your helpEd Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted February 4, 2005 Report Share Posted February 4, 2005 Gateway address? Can you PM me the address you're using in the virtual server setup? I want to see whether it's the public (outside) IP, or an IP from inside your network. I'll be able to tell from the address itself. Quote Link to comment Share on other sites More sharing options...
