Sentry Posted February 11, 2005 Report Share Posted February 11, 2005 I am trying to set up an XP Pro box (with SP2) on a workgroup network consisting of a Win2K file server, and two Win2K workstations along with a couple Win98 machines. I have tried everything I can think of to get this XP box on the network. It's running Netbios over TCP/IP, DHCP, and I've tried using the wizard and not using the wizard to get it on the network. No matter what I did I kept getting the 169.xxx.xxx.xxx internal address that it assigns when it can't a see a network.In a fit of desperation I applied a set IP address. I can now use the network to get out on the internet, I can ping other machines on the network, other machines can see the XP pro box, but it will not share network resources. It won't join the workgroup. It says that I don't have permission or authority to do so. I'm using an existing account that worked perfectly on a Win98 machine (the xp box is replacing the Win98 box.)Any ideas? What am I missing? I'm more of a Linux guy and I'm really starting to hate XP.Thanks. Quote Link to comment Share on other sites More sharing options...
draggin Posted February 11, 2005 Report Share Posted February 11, 2005 Check in services to see if the DHCP client is running, start >> setting >> ctrl panel >> admin tools >> servicesTim Quote Link to comment Share on other sites More sharing options...
Sentry Posted February 14, 2005 Author Report Share Posted February 14, 2005 Thanks for the post Tim - I'll give that a try. Question though... will that stop a PC from joining a workgroup even if I've assigned an IP address? It's just a simple peer to peer network for crying out loud. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted February 15, 2005 Report Share Posted February 15, 2005 If you're getting a 169.x.x.x address, it isn't a matter of joining a workgroup, or not. You're not getting a valid IP Address on your network, so the PC's won't communicate. They all have to be on the same subnet (192.168.1.x for example). Quote Link to comment Share on other sites More sharing options...
draggin Posted February 19, 2005 Report Share Posted February 19, 2005 The box that is issusing the DHCP IP's have you checked to make sure that it has a big enough pool of IP addreses to issues to all the PC's?? They can be set up say to issue IP addresses from say 192.168.1.20 to 192.168.1.25 and if you have 6 computers on the network you have a problem (don't forget printservers if they are dhcp). Also check that "Computer Browser" is running in services Control panel >> Adminastrative tools >> services, if not start it and try adding to the workgroup again.Tim Quote Link to comment Share on other sites More sharing options...
