allyk Posted March 11, 2005 Report Share Posted March 11, 2005 my boyfriend upgraded his vga driver on his computer last night he runs win xp pro, , after upgrading it he reestarted the pc, now it boots up to the windows (loading)moving bar and then the screen goes blank, the pc contunues booting up, but nothing shows on the screen, he gets all the normal win boot up noises but notihng on the screen, he has tried booting it up in safe mode and off the disc but notihng seems to work, please help.......thanks Quote Link to comment Share on other sites More sharing options...
djohn Posted March 11, 2005 Report Share Posted March 11, 2005 It sounds as though the driver update did not take. Re-boot and tap the F8 key to take you to the boot screen where you chose "Safe Mode" from, this time select "Safe Mode with Networking" from the choices offered. This will give you the display back in basic mode, it will look strange, rather like an oil painting with large text and graphics.From here re-install your new driver or return back to the old driver if you can't get the new one to work.While in safe mode right click your mouse on the desktop, choose properties > settings > advanced > monitor and set the refresh to 60 hertz if using a TFT type monitor.Please post back if you require further help. :) Quote Link to comment Share on other sites More sharing options...
allyk Posted March 11, 2005 Author Report Share Posted March 11, 2005 it does the same thing when he tries to start it in safe mode and off the cd, the screen just seems to die after the boot up screen.... any ideas would be fantastic, thanks Quote Link to comment Share on other sites More sharing options...
djohn Posted March 11, 2005 Report Share Posted March 11, 2005 Hi allyk, Its important that you choose "Safe Mode with networking" not just "Safe Mode". Have you tried this option? :) Quote Link to comment Share on other sites More sharing options...
allyk Posted March 13, 2005 Author Report Share Posted March 13, 2005 it does not boot up in either mode!!!, think he has sussed it now, he has a Silicon Image SiI 3112 on his hard drives, he tried to do a recovery but it does not detect the hard drives, he needs to get the installation drivers disk, think we may have sorted it, thanks for your help anyway. :) :thumbup: Quote Link to comment Share on other sites More sharing options...
