XP will not explore a CD, goes to desktop
atco
Hello all,
My first post after spending hours searching for a solution to this problem, but I came up with nothing, I am hoping someone here can help.
My PC is running XP Pro and has 3 hard drives (C, D and F) and my DVD/CD RW drive was E.
I burned a DVD last night and after the burn finished the computer unexpectedly shut down (I used Nero for the burn, which was successfully done).
It rebooted but when I went to check the disk I clicked on E and then Explore and all I got was the desktop. Right clicking to show properties also showed the DVD as empty. I could not open the DVD either. However the disk contained pictures and when I autoplayed it, it displayed a slideshow of the images.
I tried the Disk on my laptop and it works just fine.
I tried other CDs and DVDs and all had the same problem, trying to explore the disk or do anything with drive E resulted in either the desktop appearing or nothing happening.
I changed the drive letter to G and everything worked perfectly I could explore, read and write.
Obviously something has screwed up in windows can anyone tell me how to fix this so I can re-assign E to my DVD drive?
I hate having unresolved problems !!
Thanks
Yes it does.
Basically I cannot assign E to my CD drive at all.
When I plugged in my Compact Flash card reader though it was assigned E and that worked perfectly...........just the CD drive will not work (I tried 2 different CD drives and both had the same problem)
