right click menu
Guest Nellie2
Guest Nellie2
Did you know that when you right click on a file or folder, the menu that appears only shows the most recently used commands for that file or folder.
To display a shortcut menu that lists every available command for a file or folder, point to the file or folder, and then press SHIFT while right-clicking it.
