Guest Min_Man Posted January 4, 2003 Report Share Posted January 4, 2003 I have real one basic player,and I want to copy audio from a website to CD........ I did what I thought was right,but when it comes to burning the CD , I try to add the clip but a message comes up saying "clip not found"............please can someone tell me how to do it from scratch........BTW I am only copying the CD for my own personal use. I also have windows media player,but the site doesnt support WMP so I cant use that.I aint a technophobe but I need instructions with diagrams !!!! LOLThanks in advance Link to comment Share on other sites More sharing options...
Craig Posted January 4, 2003 Report Share Posted January 4, 2003 Have you downloaded the file to your computer, or is it a steaming audio file (by this i mean does it play direct from the website)?Craig. Link to comment Share on other sites More sharing options...
Guest ellas Posted January 4, 2003 Report Share Posted January 4, 2003 did you d/load the clip to your harddrive,also I have d/loaded r/p clips only to find there just a link to the clip on the internet so making it impossible to save,by the way realone is a improvement on basic as long as you config it properly otherwise it takes over your system. Link to comment Share on other sites More sharing options...
Guest ellas Posted January 4, 2003 Report Share Posted January 4, 2003 craig stop posting answers before me Link to comment Share on other sites More sharing options...
Guest Min_Man Posted January 4, 2003 Report Share Posted January 4, 2003 That was a quick reply !!! LOLIt plays direct from the site onto realone...............I have saved in an audio playlist,but I cant seem to copy the file to CD..........I have found that a problem as well Ellas Link to comment Share on other sites More sharing options...
Craig Posted January 4, 2003 Report Share Posted January 4, 2003 Some how we need to get the file you want saved to your hard disk so you can burn it to CD.My Sound Blaster Audigy comes complete with software that enables me to record what i am hearing on my PC.This type of software will enable you to record the clip while listening to it (plus any other noise like mouse clicks!).So we need to find somewhere that has this type of software for download, unless you have something like it already?Craig. Link to comment Share on other sites More sharing options...
Guest ellas Posted January 4, 2003 Report Share Posted January 4, 2003 what o/s if xp realone is easy to control if you have sp1. Link to comment Share on other sites More sharing options...
Guest Min_Man Posted January 4, 2003 Report Share Posted January 4, 2003 I have ME...........I have AMD Athlon 1gig & soundblaster live 1024 Link to comment Share on other sites More sharing options...
Craig Posted January 4, 2003 Report Share Posted January 4, 2003 have you got any software installed for your sound blaster?.i.e. a sound recorder? Link to comment Share on other sites More sharing options...
madboy33 Posted January 4, 2003 Report Share Posted January 4, 2003 this one sounds like a file from msn that is protected, i assume you can not right click on it?if you want the "BURNABLE CLIP" you will have to pay for it or give 100 credits up of your 500 that are freemadboy33 Link to comment Share on other sites More sharing options...
Guest ellas Posted January 4, 2003 Report Share Posted January 4, 2003 strange avatar there Min_ Man I keep thinking its a bit dirt on my monitor Link to comment Share on other sites More sharing options...
Guest Slartibartfast Posted January 4, 2003 Report Share Posted January 4, 2003 Hi all,Not too sure if this is strictly within the T&C's so if a mod would like to review/remove it, I shan't be offended :P Have a look at (THIS BIT NOT ALLOWED-edited by madboy33) It claims to convert streamed audio into savable files, but I couldn't possibly confirm as I haven't used it :blink: Cheers ...........Slarty B)not allowed as this also has a control in it(madboy33).........SORRY SLARTI Link to comment Share on other sites More sharing options...
Guest ellas Posted January 4, 2003 Report Share Posted January 4, 2003 I let madboy review this as hes got a thing about copyright issues Link to comment Share on other sites More sharing options...
madboy33 Posted January 4, 2003 Report Share Posted January 4, 2003 reviewed and deleted as has a cookie control and a player to installnot condoned here :) Link to comment Share on other sites More sharing options...
madboy33 Posted January 5, 2003 Report Share Posted January 5, 2003 so what do you think of mine then.....lol Link to comment Share on other sites More sharing options...
Guest Min_Man Posted January 5, 2003 Report Share Posted January 5, 2003 As a new member I dont wish to offend !!! LOL :P :lol: :ph34r: Link to comment Share on other sites More sharing options...
