Front Page 2003
madboy33
Hi all
I have this niggly problem in FP2003 (beta version)
when i press the enter key instead of going down onw line it goes down 2(a new paragraph)
I know in FP2002 it was as easy as holding the shift key to make it go down 1 line only. However in FP2003 it does not do that
Any ideas anyone?
Hi Madboy
I imagine it isn't too different to Frontpage 2000 in this respect. If you select Format - Paragraph ensure that it is set for single line spacing. Also you can set the number of lines before or after a paragraph - it's similar in MS Word.
Pete
The only other thing I can think of is that the style you are using (presumably Normal style - the default one) needs the paragraph spacing settings changing. I haven't got Front Page so I can't try things out. :blink:
May be you know about this MS Frontpage support site, but here's the link anyway. It might come in handy. There's loads of "how to" articles. Frontpage Support Site
Sorry I can't be of more help.
Pete
