Guest TheSentinel Posted December 24, 2002 Report Share Posted December 24, 2002 HelloI've posted this here at our GAV forum, but due to the lost entries here I'll post it here too This are tools, I'm using on my comouters at home and in my company I'm working.Some are very useful...GreetzUdoRegistry Optimizerhttp://fdns-software.deThis program is in german, I'm not sure if this is offered in other langauges.. .so please have a look at that website.I'm using it for 2 years now (Win98SE) and it's working fast, proper and without any problems.=============================================Pardon translatorhttp://www.softbeartech.comThis is a small, but effective program for short translations into nearly all European languages. It's helpful when wanting only one word translated.=============================================Crypting program and lot of similar stuffhttp://www.utimaco.de/eng/indexmain.htmlIf you're looking for a small, but simple working crypting program, try Ultimaco SafeGuard. Works great.=============================================PingPlushttp://www.netinfo.co.ilPingPlus is a new freeware Internet utility, designed for Windows 95 and Windows NT.It is an easy to use fully configurable and multithreaded program with an intuitiveuser interface.PingPlus allows an Internet user to:- ping a remote host over the network- trace the route to a remote host over the network- look up a domain name from its IP address or an IP address from its domain name- check up the localhost and the Winsock dataPing is a network diagnostic tool used with TCP/IP internets to test reachabilityof destinations by sending them ICMP echo request and waiting for a reply. The termis now used like a verb as in, "please ping host A to see if it is alive."Trace route is a network diagnostic tool that reports the list of gateways betweenthe source and a particular destination.Lookup is a network information tool that returns the official host name, IPaddress and alias (if it exist) from the DNS. DNS is the on-line distributeddatabase system used to map human-readable machine names into IP addresses.System Requirements:- you need to have Windows 95 or Windows NT installed on your computer- no special hardware is required- you need to have a TCP/IP network- ping requires ICMP.DLL in your windows\system or winnt\system32 directory=============================================SuperScanhttp://www.foundstone.comhttp://www.foundstone.com/knowledge/free_tools.htmlThis program is like a "swiss army knife". There are lot of other tools (2nd link) but read here:SuperScan is a powerful connect-based TCP port scanner, pinger and hostname resolver. Multithreaded and asynchronous techniques make this program extremely fast and versatile.Perform ping scans and port scans using any IP range.Use a text file to extract addresses from.Scan any port range from a built-in list or any given range.View responses from connected hosts.Modify the port list and port descriptions using the built in editor.Merge port lists to build new ones.Connect to any discovered open port using user-specified "helper" applications.Assign a custom helper application to any port.Save the scan list to a text file.Transmission speed control.User friendly interface.Comprehensive help file.=============================================TCPViewhttp://www.sysinternals.comTCPView is a Windows program that will show you detailed listings of all TCP and UDP endpoints on your system, including the owning process name, remote address and state of TCP connections. TCPView provides a conveniently presented subset of the Netstat program that ships with Windows NT/2000/XP.TCPView requires Windows 98, Windows Me, Windows NT 4.0, Windows 2000 or Windows XP.=============================================iISystem Wiperhttp://nn101.virtualave.net/Attention: there's a pop-up windows appearing!iISystem Wiper allows you to clear the history of your activites from you computer. Many programs store information about your activieties on thecomputer. Some of this information is easy to clear, such as the History, but other information can be hard to locate and clear, for example the cookie index file. iISystem Wiper allows you to clear this information with a click of a button. In addition to the lack of privacy this stored information causes, the fileas can also take up large amounts of space on you hard drive. Internet Explorer's temporary files can take up hundreds of megabytes of space. iISystem Wiper will even automate the process of wiping clean your computer. All you have to is select what items you want cleared and iISystem Wiper will clear your computer everytime it is shutdown.=============================================This list will be continued..... Link to comment Share on other sites More sharing options...
