Problem with booting a hard drive
  • 4 weeks later...
ok a few questions.
1) How did you re-connect 'the other one' - Primary/Secondary IDE Master/Slave or SATA?
2) If it's an IDE drive have you got the jumpers set correctly (if you're changing it from a master to a slave drive you'll probably need to change that.
3) This shouldn't be a problem but how big is the drive?
4) Can you see it in the BIOS?
