Craig Posted May 27, 2003 Report Share Posted May 27, 2003 I pressed the power button on my computer this morning then I left the room to do other things while it was booting.Two minutes later I return to find my monitor has not come on.I switch it all off and turn it on again, I wait a while and see no hard disk activity, and still my monitor sits on stand by.At this point I eliminate a possible graphics card problem as my monitor would come up with 'No Signal' on it.So I then remember I installed the optional 'D-Bracket' that came with my MSI M/B, on this bracket their are two USB2 ports and a very useful 4 LED light display that shows red or green lights.I found the combination of the lights in my M/B book and it said 'Memory Detection Test, Testing onboard memory size, The D-LED will hand if the memory module is damaged or not installed properly'.At this point I was thinking to myself it was alright 10 hours ago so what’s wrong now?!So I took the lid off my case and took out my Novatech RAM which I had about 4-6 weeks ago, and the computer booted up fine. Thinking it was strange that I have three RAM sticks and I choose the right one first time, I stuck it back in and the computer booted up fine again!All three sticks were in position before I took one out, and I didn’t move my computer so I don’t understand what the problem was,Has anyone had this sort of problem before with faulty RAM that isn't faulty?!Craig. Quote Link to comment Share on other sites More sharing options...
Guest moon Posted May 27, 2003 Report Share Posted May 27, 2003 'Creep' is a reality, Craig, the constant expansion and contraction of components causing bad seating. I reseat everything whenever I've got the case off. Bit of luck on your part ? :) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted May 27, 2003 Report Share Posted May 27, 2003 Has anyone had this sort of problem before with faulty RAM that isn't faulty?!what :huh: Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted May 27, 2003 Report Share Posted May 27, 2003 Pretty Please Craigy Waigy...(PM)???? :P Quote Link to comment Share on other sites More sharing options...
