damasta Posted February 11, 2006 Report Share Posted February 11, 2006 Hi allI have a serious Problem with a process called "system". user name for that is system too.systemprocess.bmpon this machine it takes like 220k mem usage, on my other it takes 54k.the problem with that is when i play world of warcraft, after 2 hours this process starts to take up to 80% of cpu usage and teh game starts lagging seriously.as soon as i restart the comp everything will work fine again.i aslo cant terminate the process.i have changed my memory, i have changed my videocard but nothing seems to be helpful.maybe someone of u guys know a resolutionthanks for now damasta Quote Link to comment Share on other sites More sharing options...
spikeychris Posted February 11, 2006 Report Share Posted February 11, 2006 XP Home or Pro?If Pro type this into run and post the results.tasklist /svc > filename1.txtIf Home: type this into run Check the system event logeventvwr.msc Click the sytem file - are there any obvious errors?Type this into run sigverif Report.If the above fails then use this http://oca.microsoft.com/en/windiag.asp to diag. Quote Link to comment Share on other sites More sharing options...
damasta Posted February 12, 2006 Author Report Share Posted February 12, 2006 XP Home or Pro?If Pro type this into run and post the results.tasklist /svc > filename1.txtIf Home: type this into run Check the system event logeventvwr.msc Click the sytem file - are there any obvious errors?Type this into run sigverif Report.If the above fails then use this http://oca.microsoft.com/en/windiag.asp to diag.got professionalImage Name PID Services ========================= ====== =============================================System Idle Process 0 N/A System 4 N/A smss.exe 1044 N/A csrss.exe 1116 N/A winlogon.exe 1140 N/A services.exe 1184 Eventlog, PlugPlay lsass.exe 1196 PolicyAgent, ProtectedStorage, SamSs svchost.exe 1364 DcomLaunch, TermService svchost.exe 1440 RpcSs svchost.exe 1532 AudioSrv, Browser, CryptSvc, Dhcp, dmserver, EventSystem, helpsvc, lanmanserver, lanmanworkstation, Netman, Nla, RasMan, Schedule, seclogon, SENS, SharedAccess, ShellHWDetection, TapiSrv, Themes, TrkWks, W32Time, winmgmt, wscsvc, wuauserv, WZCSVC svchost.exe 1596 Dnscache svchost.exe 1648 LmHosts, RemoteRegistry, SSDPSRV, WebClient spoolsv.exe 1884 Spooler CCPROXY.EXE 2012 ccProxy ccSetMgr.exe 2032 ccSetMgr NAVAPSVC.EXE 196 navapsvc nvsvc32.exe 224 NVSvc SNDSrvc.exe 472 SNDSrvc svchost.exe 572 stisvc ccEvtMgr.exe 724 ccEvtMgr SymWSC.exe 924 SymWSC SAVSCAN.EXE 1604 SAVScan alg.exe 1720 ALG devldr32.exe 1588 N/A explorer.exe 532 N/A ahqtb.exe 1008 N/A ccApp.exe 828 N/A jusched.exe 780 N/A rundll32.exe 1800 N/A mssysmgr.exe 392 N/A hpotdd01.exe 2112 N/A soffice.exe 2168 N/A soffice.bin 2176 N/A svchost.exe 3056 HTTPFilter iexplore.exe 3832 N/A msimn.exe 3380 N/A msmsgs.exe 2188 N/A cmd.exe 3108 N/A wmiprvse.exe 2308 N/A tasklist.exe 3576 N/A and its the second process form top whihc is buggnin mehere the unsigned filessigverify.bmpwhereas i dont have th ati videocard installeda anymoreproblem was tehre with other videocard toochanged videocard because i thought it might help Quote Link to comment Share on other sites More sharing options...
spikeychris Posted February 12, 2006 Report Share Posted February 12, 2006 Are you getting any ati2mtag.sys errors in event viewer? Quote Link to comment Share on other sites More sharing options...
damasta Posted February 17, 2006 Author Report Share Posted February 17, 2006 Are you getting any ati2mtag.sys errors in event viewer?ifugured out what the problem was....it was an irq conflict which windows didnt detect....sound and lan had teh same interrupt and after 2 hours windows couldnt handle it anymore....now i changed teh irq settings adn evrything is finethx for ur helpKevin Quote Link to comment Share on other sites More sharing options...
