Yeah Ano Posted March 16, 2006 Report Share Posted March 16, 2006 Hi all,Ill get straight to the point. I have a desktop PC cabled to my wirless router and 2 laptops that work wirelessly off it. To my knowledge (add yes i have double checked) they all have the same settings and are all part of the same workgroup. Problem is that i can access one of the laptops from the PC but not the other one - please see attached file for error message. The router can see it as its listed in the DCHP entry list and i ping the laptop using its IP address but when i try to accsess the laptop by either mapping to it (\\"laptop name\c$ - which has been shared) or trying to access it through my network places->view workgroup computer it comes up with attatched error message. All computers are on the same o/s and service pack. I have also set the MS firewall to off and the norton one to exclude the ip range of my network.Any ideas as its gone over my head and causing a head ache!!! Quote Link to comment Share on other sites More sharing options...
Yeah Ano Posted March 18, 2006 Author Report Share Posted March 18, 2006 I have managed ti fix it!!!I ended up adding another protocol to the network connection on all 3 computers (NWLink IPX/SPX/NetBIOS Compatible Transport Portocol). Now all 3 computers can access each others resources.Dont know why i had to add that though as TCP/IP protocol should have done it all on its own.Any ideas as to why? Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted March 18, 2006 Report Share Posted March 18, 2006 Did you ever try it with your firewall(s) completely off instead of just allowing a subnet? Quote Link to comment Share on other sites More sharing options...
Yeah Ano Posted March 22, 2006 Author Report Share Posted March 22, 2006 Cant remember to be honest - doesnt help that much really does it. What would it mean though if i did and it still didnt work? Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted March 22, 2006 Report Share Posted March 22, 2006 It would mean that your firewall was still blocking something you though you had allowed. Quote Link to comment Share on other sites More sharing options...
