somtaran Posted June 13, 2006 Report Share Posted June 13, 2006 I have connected a printer to my server and shared it to all users then I connected to the printer from several clients. My problem is that when I reboot any of the clients they lose the connection to the printer. I have to manually reconnect. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted June 13, 2006 Report Share Posted June 13, 2006 Hello, and welcome to the Windows Forum.How do you 'connect' to that printer? Via Control Panel, Printers and Faxes, Add Printer ? (Assuming that the clients are Windows XP). Quote Link to comment Share on other sites More sharing options...
somtaran Posted June 13, 2006 Author Report Share Posted June 13, 2006 Yes this is how I connect: Via Control Panel, Printers and Faxes, Add Printer. Oh and ta for the welcome Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted June 14, 2006 Report Share Posted June 14, 2006 I have never seen this before. Adding a network printer is usually permanent, and the printer definition remains in there even if the physical printer or the server is down.Can you check the registry on one of the clients, just before shutdown, then again after startup. What do you have in HKEY_CURRENT_USER\Printers\Connections ? Also HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Devices ?And because I am curious, can you also check HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Print\Providers\LanMan Print Services\Servers ? Quote Link to comment Share on other sites More sharing options...
