macman64 Posted June 13, 2006 Report Share Posted June 13, 2006 I am in the process of switching to exchange. I switched one person over and now when they close outlook the process does not close. It still runs in task manager. This means i can't open outlook until I end the process. Any ideas? We have both trendmicro and cybersitter installed. I unloaded trendmicro and disabled cybersitter. I even ended all processes for those two programs still have the same problem. I have this problem on all the windows 2000 computer i have tried its outlook 2003. I am out of ideas. I don't think I have any more 3rd party outlook things installed. Any ideas? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted June 13, 2006 Report Share Posted June 13, 2006 Hello, and welcome to the Windows Forum!After terminating the Outlook process, can you try to start OL in safe mode (using the /SAFE program switch). Does it also happen when shutting down OL from safe mode? Quote Link to comment Share on other sites More sharing options...
macman64 Posted June 13, 2006 Author Report Share Posted June 13, 2006 I have not tried using Safe mode. It asks if you want to use it if i waited awhile before ending the process. I will give that a shot and report back. Quote Link to comment Share on other sites More sharing options...
