pi3rc3 Posted June 29, 2006 Report Share Posted June 29, 2006 i just built a new pc and im trying ot install a brand new copy of windows xp media center 2005. i get up to the screen where it ask me to select partition and all i have for selection is unpartitioned space. so i press c to create a partition and accept the maximum amount and hit enter and it just takes me right back to select partition screen without adding anything new...anyone know why this may be? i tried using a lower amount for the partition but that didnt work either. Quote Link to comment Share on other sites More sharing options...
Kike Posted June 30, 2006 Report Share Posted June 30, 2006 Perhaps the disk doesn´t work. If you can, try to install an older windows version (like win 2000), just to discard this situation, and with that operating system also you can create a partition to install the XP later. Just remember, well, as a commentary, I have had several problems when I have tried to install XP on computers "home made". Quote Link to comment Share on other sites More sharing options...
