Guest LB Posted June 19, 2003 Report Share Posted June 19, 2003 Hi all,finally upgraded to an Athlon XP with an MSI KT3V Ultra mobo and 512mb DDR.One of the utilities that came with my mobo was a temp monitoring program. Seeing as i only had a P3 1ghz before, i never thought much about the CPU temp but now frying the CPU seems to be a possibility. Anyone any idea what the optimum CPU temp should be as mine is running at between 59 & 62 degrees currently. Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted June 19, 2003 Report Share Posted June 19, 2003 As long as the cooler is correct for the CPU and it's fitted correctly. (no thermal paste - AMD only recommend pads)What processor are you using?My Athlon XP1900 runs between around 52 (now) and 59 (hot day).My motherboard is running at 32c now also. ;) Quote Link to comment Share on other sites More sharing options...
Guest LB Posted June 19, 2003 Report Share Posted June 19, 2003 XP1800, and the mobo documentation said to ensure that thermal paste IS used!!! Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted June 19, 2003 Report Share Posted June 19, 2003 ...I read this somewhere, as I replaced a heatsink on my own PC. I was told that AMD only support the use of thermal pads and did not recommend the use of thermal paste (other than for testing etc). Also don't mix pads and paste...Clean contacts with 'isopropyl alcohol' thoroughly before renewing.Have a look HERE. - WMP file of 2MBGood list of movie files for AMD processor removal/refitting HERE. ;) Quote Link to comment Share on other sites More sharing options...
Guest LB Posted June 19, 2003 Report Share Posted June 19, 2003 thanks for that scarthy, the video is quite good!!!!Never seen anything like that at intel Quote Link to comment Share on other sites More sharing options...
Bluecow Posted June 19, 2003 Report Share Posted June 19, 2003 my 1.3 duron runs at between 55 - 61. the motherboard is about 32 today.I think as long as you keep it below 70 you will be fine. Quote Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted June 22, 2003 Report Share Posted June 22, 2003 n/p mate. Hope it helped. ;) Quote Link to comment Share on other sites More sharing options...
