Mackenzie123 Posted August 2, 2006 Report Share Posted August 2, 2006 I recently rebooted my computer, but i first loaded all my files into an external harddrive. Now that my computer is rebooted, when I try to bring my files in from my external harddrive, it says "Cannot Create or Copy: Access Denied--Make sure the disk is not full or write-protected and that the file is not currently in use". I can't figure out how to move my files, I have done this in the past and it worked perfectly. please help me!note: i have work on it and i need it and if i don't fix this i could lose my job! please help me!! Quote Link to comment Share on other sites More sharing options...
dadyassa Posted August 2, 2006 Report Share Posted August 2, 2006 Dont know a lot about file sharing , but is the external HD set for NTFS ?Just googled this thread on it might help. scroll down to accepted answer. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted August 3, 2006 Report Share Posted August 3, 2006 Can you otherwise open/access the files on the second HD? Can you check the files' properties and security settings? Quote Link to comment Share on other sites More sharing options...
