Ryuken Posted October 4, 2006 Report Share Posted October 4, 2006 Good eveningI´m having some issues with files in a file server, and maybe someone here can help me out with this:1) First, I´d just like for someone to tell me if what I´m doing will have the result I expect it to have. I´m planning on setting folders permissions so that: a) A certain group will be able to create/change files within it; B) Although the group has write permissions, I want only the original file creator user to be able to rename or delete it. For that, I´m planning on setting the following: - GROUP: Read/Write/Execute - CREATOR OWNER: Modify/Read/Write/ExecuteWill that work?2) Someone knows some kind of file monitor for NTFS, that will log something like: which file was created/changed/deleted, when, where and by whom?I thank you all in advance Quote Link to comment Share on other sites More sharing options...
Ryuken Posted October 4, 2006 Author Report Share Posted October 4, 2006 Well, answering my own post:1) It works right the way I wanted. That's less one problem :D2) Still couldn't find a file monitor that does what I need. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 5, 2006 Report Share Posted October 5, 2006 Sorry for no replies; welcome to the Windows Forum anyway!Glad you got your first issue resolved, but sorry I don't know of any file monitoring tool. I am sure though that it exists - I'm sure the need is there on many shared systems. Quote Link to comment Share on other sites More sharing options...
Ryuken Posted October 5, 2006 Author Report Share Posted October 5, 2006 Thanks for the welcoming ^^As for the File Monitor, perhaps I've found something.My teacher showed it to me, in W2K3 Server, probably works for XP and 2000 Pro/Server as well.Apparently, Windows Event Log System can audit changes in files and folders (although the log can be a bit confusing to read).If I remember correct, all you have to do is:1) Choose a folder/file to audit, go to Security Yab > Advanced > Auditing > Add. Set permissions the way you want (my needs call for a Everyone with all kinds of permissions - write, modify, and so on - both for Success and Failure).That being done, go to Local Policies > Event Policy (not sure about this path, but what you'll want to do is change Event Policies). Then you just set System Event to log about everything. Open a command line and type gpupdate so it starts to work right away.Like I said, doing it can be a little confusing, since a simple file creation may add about 20 lines to your System Log (when only one will showhe "File Createad"), but that's okay for a start, I hope :DAnd Pat, don't worry about a thing. I guess that's more than natural when a post doesn't has any replies, mainly one like this one, which is asking for something that not everyone knows.Well, I just hope that my doubts can be helpful to someone else out there. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 5, 2006 Report Share Posted October 5, 2006 If you are going to implement it, please post your results here. I find it very interesting that you can monitor files via event logs! Quote Link to comment Share on other sites More sharing options...
