Urgent - Wmi Problems
Guest Damo
After doing a bit of digging I have another possible answer.....
Here is a response from Microsoft:
The one time when this was investigated, the process has loaded an interception
dll with a random name, causing the crash. The common denominator was a
dll with extension TMP.  This was confirmed to be a virus later on.
Can you do an antivirus scan and confirm if you can see this random DLL name
in crash data ?
Give it a try, make sure your AV is upto date and run a FULL scan. Pay particular attention to *.tmp files (ie Temporary Internet Files)
Cheers
Damo
