switching between dual and single display setups
I've just set up a dual display but would like to use it only at certain times, so I'd like to be able to easily switch between dual and single display without having to manualy alter the display settings (this screws up the organization of my desktop icons). I hoped I could set up 2 users, one that uses a dual display and one that uses a single display that way I could configure a specific desktop layout for each, but as far as I can tell there is no way to have indepenent display settings for each user.
Any ideas?
I'm running WinXP pro, SP2, and my graphics card is a Radeon 9550 if that makes any difference.
