narkant Posted January 31, 2007 Report Share Posted January 31, 2007 i turned on my computer this morning and i could'nt log into any of my user accounts i tried running windows in safe mode but it still would not work i need help please! any ideas? Quote Link to comment Share on other sites More sharing options...
tk27 Posted January 31, 2007 Report Share Posted January 31, 2007 i turned on my computer this morning and i could'nt log into any of my user accounts i tried running windows in safe mode but it still would not work i need help please! any ideas?i assume this is an xp os. try ctrl+alt+del twice at the user welcome screen, regular login ui/pass windows pops up, try to login as "administrator" with an empty password.otherwise:find a password recovery\delete (console based) OS you can boot from. e.g. http://home.eunet.no/pnordahl/ntpasswd/bootdisk.htmlgood luck! Quote Link to comment Share on other sites More sharing options...
narkant Posted January 31, 2007 Author Report Share Posted January 31, 2007 i turned on my computer this morning and i could'nt log into any of my user accounts i tried running windows in safe mode but it still would not work i need help please! any ideas?i assume this is an xp os. try ctrl+alt+del twice at the user welcome screen, regular login ui/pass windows pops up, try to login as "administrator" with an empty password.otherwise:find a password recovery\delete (console based) OS you can boot from. e.g. http://home.eunet.no/pnordahl/ntpasswd/bootdisk.htmlgood luck!i tried doing these but nothing i also ried using my own system recovery disk but it wont run thanks for the advice all the same :) Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 1, 2007 Report Share Posted February 1, 2007 When you say 'login', is that to the local computer, or to a network domain?When you say "couldn't login", what does that mean, exactly? Do you get an 'incorrect password' message, or what?Finally, what do you mean "my own system recovery disk but it wont run"; please clarify. Quote Link to comment Share on other sites More sharing options...
