Chromepro Posted February 18, 2007 Report Share Posted February 18, 2007 For some reason whenever I try to run Itunes it will give me a "A Problem is detected with your audio configuration" I try to go to sounds and devices but that doesnt work eitherthe words are transparent and i cant click anythingi unplugged my speakers form the sound jack then plugged it in then restarted then it worked for a sec then it didnt..Can somebody help? Thanks Quote Link to comment Share on other sites More sharing options...
cozofdeath Posted February 19, 2007 Report Share Posted February 19, 2007 Give this a shot...http://docs.info.apple.com/article.html?artnum=304424 Quote Link to comment Share on other sites More sharing options...
Chromepro Posted February 19, 2007 Author Report Share Posted February 19, 2007 Ive done it a ton of times. never works for me :( Quote Link to comment Share on other sites More sharing options...
cozofdeath Posted February 20, 2007 Report Share Posted February 20, 2007 Other than Itunes does your audio work fine? Quote Link to comment Share on other sites More sharing options...
Chromepro Posted February 24, 2007 Author Report Share Posted February 24, 2007 actually the problem just went away now at complete randomiTunes likes to not work and not load in which teh only solution is to renistall itthis gets very annoying as I do it 3 times a day.. Quote Link to comment Share on other sites More sharing options...
