Schmactor Posted March 14, 2007 Report Share Posted March 14, 2007 About every 10 minutes or so my computer makes an alert sound. No information windows pop up, nor any kind of message, and it happens even when no programs are running. It usually happens every 10 minutes, but sometimes is completely unpredictable. The only thing I've found that coincides with the times of the alerts is the following entry in the event viewer:.NET Runtime Optimization Service (clr_optimization_v2.0.50727_32) - Service work was interrupted due to the following reason(s): USER_INTERRUPT (Mask: 0x04)Anyone know what's going on and how I can stop it? Quote Link to comment Share on other sites More sharing options...
Schmactor Posted March 15, 2007 Author Report Share Posted March 15, 2007 The event viewer entry is also listed as error #1108 whenever it comes up. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 15, 2007 Report Share Posted March 15, 2007 Welcome to the Windows Forum!I *think* it is another application that causes this to occur. Can you see anything else (another application) listing something in the Event Log when this happens?The reason why I believe this is this thread and other similar Google search results. Quote Link to comment Share on other sites More sharing options...
Schmactor Posted March 20, 2007 Author Report Share Posted March 20, 2007 Thanx for writing!As I said, it happens even when no other programs are running. But I'm sure there are a lot of background programs running all the time. However the only thing I can find in the event viewer is what I already posted. I don't know why it doesn't say anything more specific.Maybe I should just remove all the .Net environments I downloaded. They aren't really necessary right? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 20, 2007 Report Share Posted March 20, 2007 If you have applications installed that require .NET Framework, then you will need to keep it/them. Applications that need them usually indicate very clearly that they need .NET Framework, and what version.If you don't know of any applications on your computer needing the .NET Framework, then it is almost safe to assume that you don't need it/them. Uninstall all of them, starting with the highest version. Quote Link to comment Share on other sites More sharing options...
