Requiem Posted March 20, 2007 Report Share Posted March 20, 2007 If I dual boot PcLinuxOS and use it for my web related stuff and I use windows as my work space for programming. I want to know that if i disable alot of stuff in windows in registry editor will they mess up linux? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 20, 2007 Report Share Posted March 20, 2007 The direct answer to your question is 'no'.But I wouldn't just go into the registry editor and start to "disable alot of stuff"; you may end up having to reinstall Windows.A good, easy, and safe way to disable things is using Startup Inspector for Windows. Quote Link to comment Share on other sites More sharing options...
