KVK Posted May 10, 2007 Report Share Posted May 10, 2007 I have a program that takes about 30 seconds to start up due to our slow network. I would like to make a small program so that when you click on the icon it simply says "loading" until the program starts. Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 11, 2007 Report Share Posted May 11, 2007 Welcome to the Windows Forum!Not exactly a Windows Support question; it may have been better posted over here. But we are not so strict around here, so no-one will yell at you Anyway, do you know how to write a program? Do you know any programming languages? Do you have any preferences - C, VB, Java, ...? Quote Link to comment Share on other sites More sharing options...
cozofdeath Posted May 11, 2007 Report Share Posted May 11, 2007 http://www.brothersoft.com/software_develo...ctor_47081.htmlhttp://www.brothersoft.com/utilities/misce...hine_24295.htmlhttp://www.tucows.com/preview/341464There are a couple of splash screen makers. Sorry they are all shareware but if you search for things like "free splash screen maker" and things like that you may find one. I believe all of them listed will inject or allow you to add the splash screen to any executable. Quote Link to comment Share on other sites More sharing options...
KVK Posted May 11, 2007 Author Report Share Posted May 11, 2007 I was going to use VB but don't know much about it. Someone gave me this code and said it should work.Set WshShell = WScript . CreateObject ("WScript.Shell")WshShell.Run "calc.exe"WshShell.Popup "Please Wait",4,"Name of program",0 Quote Link to comment Share on other sites More sharing options...
