piratenaapje Posted June 3, 2007 Report Share Posted June 3, 2007 Recently, I bought a new router since of my old one breaking down. It's a D-LINK DI-524. Problem is, I can see it, but I can't connect to it properly. When I try to connect to it, it just says "waiting for network" for a minute, after that it says "not connected" next to the network name.When I try to do this under Ubuntu (linux distro), I can connect to it perfectly.Weird thing is, I can browse the internet for a min or 5 althought it says I'm not connected (there's also a red x at the wireless thingy in the system tray).When I type in ipconfig /all in a command prompt, it shows the correct information, as if I was connected to the network normally.My next attempt was to not let it assign a ip adress automatically to my laptop, and make it static. Now I am able to connect to it for about 15 secs. Then the same problem as above arrises.Help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
piratenaapje Posted June 3, 2007 Author Report Share Posted June 3, 2007 I can connect to it if i disconnect my main pc from the internet. Anyone know why this could be happening? Quote Link to comment Share on other sites More sharing options...
piratenaapje Posted June 3, 2007 Author Report Share Posted June 3, 2007 I can connect to it if i disconnect my main pc from the internet. Anyone know why this could be happening?I noticed the following in the log of my router:Sunday June 03, 2007 09:33:08 Disassociated: 00-18-DE-48-84-42 because RX deauth reqThis happens to be the mac-adress of the laptop. Quote Link to comment Share on other sites More sharing options...
mcb2001 Posted June 4, 2007 Report Share Posted June 4, 2007 do you have any kind of security on net?Like encryption, (WEP, WPA).and in that case, have you forgotten to set it up on the labtop? Quote Link to comment Share on other sites More sharing options...
