samuelpenkar Posted June 27, 2007 Report Share Posted June 27, 2007 When I have a running program and I minimize the window, it disapprears and I have to go to the task-manager in order to restore the window again. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted June 27, 2007 Report Share Posted June 27, 2007 Welcome to the Windows Forum.Can you see the program when you click through the running programs with Alt+Tab (holding down the Alt key, then clicking the Tab key repeatedly) ? If you see it, can you activate by stopping on it? Quote Link to comment Share on other sites More sharing options...
samuelpenkar Posted June 27, 2007 Author Report Share Posted June 27, 2007 Welcome to the Windows Forum.Can you see the program when you click through the running programs with Alt+Tab (holding down the Alt key, then clicking the Tab key repeatedly) ? If you see it, can you activate by stopping on it?Yes, I can see / run it by using the Alt+Tab key.I just cannot see the program in the task bar below. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted June 27, 2007 Report Share Posted June 27, 2007 Is it only one program that you cannot see in the taskbar, or are all programs invisible in the taskbar? Quote Link to comment Share on other sites More sharing options...
