ed8020 Posted September 3, 2007 Report Share Posted September 3, 2007 I was removing XP 64 and installing xp pro. I ran the wizard and saved the files to free space on another HD partition. I formatted the C drive and installed xp pro. When I ran the FAS wiz it wouldn't let me install the Dat files because they were not on "removable media". I bought a dvd burner and copied the dat files to dvd, ran the wizard and it said " an error occured while the wizard was loading your data. The wizard cannot find your files and settings in the source location".All I really want is to extract the outlook qst file that is tied up in there. I copied everything else I wanted before running the fst wiz.Any suggestions? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted September 3, 2007 Report Share Posted September 3, 2007 Welcome to the Windows Forum.I have never used the FAST wizard (although I recommend it all the time), so I do not know what format it saves its data.But I found the following articlehttp://windowsxp.mvps.org/fast.htmand there are many more using your error message on Google. Let us know how it goes. Quote Link to comment Share on other sites More sharing options...
