jumpingjay Posted January 29, 2008 Report Share Posted January 29, 2008 I was trying to connect my computer to my HDTV, and in the process of trying to get the screen resolution correct for the HDTV, I messed it up so badly that I can not even log in anymore. All I see is the 'shut down' option on the welcome screen (and since I have the login password protected, I have to make it past here before I can get to windows to change my resolution... Arghhhh!).Anyways, I have tried disconnecting my HDTV, and pluging the regular monitor in... no help. I took the video card out and booted the computer to see if it would reset something... nada. All I get is the welcome screen with only the 'shut down' option. And the mouse won't move off of the screen to the top, bottom, left, or right, so I can't even luck out to hit the login button. Man...Does anyone know of any way I can reset the system to a default resolution (800x600 or something similar), without logging into windows, or of some way I can skip the boot screen altogether. Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 29, 2008 Report Share Posted January 29, 2008 Welcome to the Windows Forum.Try to boot into Safe Mode ([), then reset the display settings. Use System Restore if necessary. Quote Link to comment Share on other sites More sharing options...
