php111 Posted March 27, 2008 Report Share Posted March 27, 2008 Hi,I am a person that has a trouble understanding a little bit. I found a real basic tutorial on OpenSSH and so far I done really great because I made it far. There are a few things I possibly need assistance with. I know there are a few I need help with but I am not sure about the rest. Here are the links below.Tutorial: http://pigtail.net/LRP/printsrv/cygwin-sshd.html7a) Make sure every Windows user has done the following at least once:Login in as the Windows user, pop a console command screen by clicking Start...Run....cmdThanks to Magno CorrĂȘa of Brazil for the tip in (7a)(8) important Pop a cygwin gwindow, harmonize Windows user information with cygwin, otherwise they cannot loginmkpasswd -cl > /etc/passwdmkgroup --local > /etc/groupIf your XP logs on to a domain, you most likely have to manually edit /etc/group. See this page.If your XP logs on to a domain, you may want to edit /etc/passwd to replace /home/username by //unc_server/path_to_home (thanks to Geoff Thomas)mkpasswd creates a password file from Windows' user list, click here for more details.mkgroup creates a group file from Windows' user list, click here for more details.Thanks to John Skiggn of Cingular Wireless in Redmond, Washington for his tweak on domain user /etc/grouphttp://pigtail.net/LRP/printsrv/passwd-group.htmlAll of the above I am having trouble with. I don't want edit the wrong line. Yes I did download the very powerful notepad++ is what the tutorial recommend to edit the lines (if needed). Regular notepad and wordpad will not work. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted March 27, 2008 Report Share Posted March 27, 2008 Sorry php111 but I'm not very familiar with setting up OpenSSH in a Windows environment. In Windows, I use a free utility called Putty which is very easy to install and use.You can download putty.exe from here:http://www.chiark.greenend.org.uk/~sgtatha...y/download.htmlMay I ask what you want to use SSH for?If Putty doesn't meet your needs, please post. Quote Link to comment Share on other sites More sharing options...
