karliki Posted March 31, 2008 Report Share Posted March 31, 2008 Hey,I was wondering if anybody could help me with two problems that I've started to experience today. The first is with IE, basically I can't highlight any text in IE so I can't cut and paste from a site, not a major problem but it is annoying. I can still highlight by holding down shift+the arrow button, it's just using the mouse to do it where the problem arises.The second problem is with windows media player and it also happens on itunes to. Basically when I add more then one song or video to a playlist it immediately starts cycling between the files. So it opens the file up for a second then opens the next one and so on and so on. I thought this might be some sort of virus I might haved picked up, so I update my definitions and did a scan but nothing came up. I've also searched the net and found nothing like this problem. Seems strange to me, any advice for either of the problems?They say it comes in three's so lets hope the next thing that goes wrong is only small.Thanks for reading and any replies I get.The versions areIE 7Media Player 11XP Pro SP2 Quote Link to comment Share on other sites More sharing options...
karliki Posted March 31, 2008 Author Report Share Posted March 31, 2008 It would seem that a simple restart was all that was needed, doh! Quote Link to comment Share on other sites More sharing options...
