KateetaK Posted April 1, 2008 Report Share Posted April 1, 2008 Alright, so here's what's going on. I am not great at explaining things so I will do my best. BTW my OS is Windows XP Media Center Edition.When I started up my computer today, a box appeared in the upper left-hand corner of my screen (while nothing else loads, not even the taskbar) and files began to appear in the box running very quickly. They were moving very quickly but I did see that most of the files began with "Deleted Files.." or something to that effect. I closed the box out since this had never happened to me before & I had no idea what was going on. Then I opened my browser (Mozilla Firefox) to see if I could check around and see what the problem is and everything was gone from my browser...all of the bookmarks, add-ons, preferences set back to default - as if I had never used it before. After that, I closed the browser and ran an anti-virus scan along with a spyware scan. They did not detect a thing. Actually, when I started up my anti-virus program (AVG) it was as if I had never used that before either.I then decided to restart my computer and the same box appeared doing the same thing as before. I immediately shut the window this time. Now my desktop picture isn't there either. I restarted Firefox and saw the same thing happen again - it was reset to default as if I were never there. So, this is what the story is so far & I have not restarted since - I came directly to this site to find some help. I would really appreciate any and all help. Thank you for taking the time to read this message. If you need any more information on my problem or anything else I may have missed, please say so and I will supply it. Thanks again, everyone.---Kate Quote Link to comment Share on other sites More sharing options...
KateetaK Posted April 1, 2008 Author Report Share Posted April 1, 2008 Anyone? I could really use the help, I don't know what the command prompt thing is doing and if I should shut it off or just let it run. I'm a little freaked to make any changes to my computer then have everything go back to default after I restart it. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted April 2, 2008 Report Share Posted April 2, 2008 Welcome to the Windows Forum.And sorry for not jumping to your help when you need it; some people are asleep at the time when you post on this forum.Anyway, first suspicion: malware. Have you an active firewall, plus up-to-date anti-virus and anti-spyware applications installed? What exactly, and when did you last run a full scan?Second, check your startup items for anything suspicious that wasn't there before; I suggest Startup Inspector. Quote Link to comment Share on other sites More sharing options...
