Alexo Posted May 9, 2008 Report Share Posted May 9, 2008 Recently, my Windows XP machine stopped recognizing my Corsair Flash Voyager drive, which I was using for half a year without any problems.When plugged into a USB port via a Dell monitor hub, it does not recognize it at all (unknown usb device).When plugged directly into one of the front or rear usb ports, it mis-recognizes it as a "SM324BC memory bar" and says that it is not formatted.Other machines have no problem accessing the flash drive, so it doesn't look like it is faulty.I installed SP3 but it did not help.Removing everything USB-related does not work as the keyboard and mouse are both USB and the system stops responding as soon as I try that.Please advise!Thank you,Alex. Quote Link to comment Share on other sites More sharing options...
