gui text color problem
i'm using a 3rd party visual style with windows xp (concave to be exact).
i installed it a few days ago, and decided to make it my default theme. however, i've run into some gui annoyances. mainly black text over black background. i've been through every setting in the advanced apearance tab in the control panel, and i've downloaded about a million different registry editors and visual style editors, but i can't seem to find the setting for this one bit of text.
example:
if i right click on a folder and select properties, most of the text in the window is black. (see image below)
my question is, is there a way to change the font color using native-to-windows settings or do i need a program, and if so, what program would you recomend if you know of any?
