zzr Posted July 23, 2008 Report Share Posted July 23, 2008 Running XP SP2 and task manager is showing Explorer.exe constantly using 47-50% CPU as is System idle process . I can't see any other programs running, the local area connection icon will often show a constant flow of traffic but disabling this makes no difference to the CPU usage for Explorer. Tried ending most processes in task manager but again makes no difference.There must be something running in the background but I can't see what. Any suggestion??RegardsBrian Quote Link to comment Share on other sites More sharing options...
Tanmaya Posted July 23, 2008 Report Share Posted July 23, 2008 Hi Brian!May Sysinternals will help you to find out the culprit B) . It has many options available regarding the system utilities. Quote Link to comment Share on other sites More sharing options...
zzr Posted July 30, 2008 Author Report Share Posted July 30, 2008 Managed to solve the problem. After using numerous spyware and virus checkers I tracked down a trojan in system32. So far everything is fine again, thanks for your input.RegardsBrian Quote Link to comment Share on other sites More sharing options...
