Reuben Posted August 14, 2008 Report Share Posted August 14, 2008 A friend of mine has a problem where by the network connection will not be made until the ethernet cable is unplugged and plugged back in - the connection will not be made at boot. Is there a simple usually correction for this or will I need to go back and find out specific router settings, I'm hoping it's just a config error somewhere on her XP install. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted August 14, 2008 Report Share Posted August 14, 2008 You could try reinstalling the network card drivers.Does your friend use an Internet service that requires authentication before accessing the Internet? Quote Link to comment Share on other sites More sharing options...
