Need Help: fix object shadows
I need help with a shadow fix... Al my cursors, objects, icon and even text has a big "drop shadow" like shadow. Here is a picture of my cursor: Shadowed cursor image
As you might, or might not see, the cursor is shadowed. Here is a picture icons and text: Shadowed icon and text image
Now, you might not see this because its shadowed for me so I cant really see the difference. But I hope its right.
The shadow seems to change with the resolution, the lower resolution, the less shadow. Does it maybe have something to do with one of my games? It sets the resolution to about 800x600 while my real is 1440x900. And when you exit the game it stays at the resolution, and you have to change manually, by right clicking the destop and choosing properties.
So, bottom line, how do I fix this? :unsure: Its really annoying! :( :angry:
PS: I have tried rebooting, SOMETIMES it works, but mostly, it either dont help, or it goes shadowed again after a while.
