pompadir Posted September 19, 2008 Report Share Posted September 19, 2008 Hello!Is there any way to open the "Wireless Network Connection" window with the command prompt?thanks :) Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted September 20, 2008 Report Share Posted September 20, 2008 You can go to a command prompt and type IPConfig for information about your settings, but I don't know of a way to configure your wireless. I'm assuming you're using Windows XP? Quote Link to comment Share on other sites More sharing options...
