problem with polish chars in remote desktop
Rafal
Hello,
I tried to find any information regarding my problem but no luck.
So here it is.
I have installed terminal services on windows 2000 server. All terminal users work on computers with Windows XP Pro or Windows XP Home. Two of them suddenly started to have problems with typing polish characters when working in terminal (one works on XP Pro, another on XP Home).
When they press i.e. Alt Gr + A sometimes it behaves like it was a shortcut and sometimes it types polish char.
I'm sure problem is with a client computer as I've tried to log on TS from it using different accounts and problem remained. I also tried to log on TS on the same accounts from other computers and problem didn't occure.
What's more. When I try to work localy on a client computer I don't have this problem. It seems there is smth wrong with a connection computer>terminal.
Windows 2000 Server and all XPs are fully updated.
Both systems have only polish programmers keyboard installed so there is no possibility that it has switched to another type somehow.
What can be wrong?
Regards
Rafal
