SquareAce Posted November 25, 2008 Report Share Posted November 25, 2008 Gateway E-6500Intel D945GBIWindows XP Sp3HPw2007 monitor with onboard speakersUsing mobo's audio, no sound cardI want to increase my audio volume. I'm using my monitor's onboard speakers, and the volume is too low. My computer came with Sigma Tel Audio device and the speaker setup will not change from 7.1. SiSandra tells me I have another audio device, Microsoft Sound Mapper, 2 Ch. Can I switch to the MS Sound Mapper device or is that something I would want to do? I've checked all the obvious volume controls (audio properties, software volumes, media player) and they are all maxed out. The Sigma Tel Audio shows me different speaker configurations but it doesn't change (speaker settings / advanced / speaker setup). I select apply / ok, and ok on the audio properties, but when I check back it goes back to 7.1. Any advice? Is there a way to boost the normal voloume? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 26, 2008 Report Share Posted November 26, 2008 Welcome to the Windows Forum.Check your monitor's specifications; some monitor speakers have a hardware volume controller.Also check out http://www.drivermax.com/ to see if you have any updated drivers for your audio device(s). Quote Link to comment Share on other sites More sharing options...
