vista boot up problem
aine
Hi, i have fitted a second hard drive . PC worked great. Cloned new larger drive from smaller drive, using Acronis. Disconnected little drive © to get the PC to recognise this larger drive (E). Did not work, message appeared "windows failed to start. file\windows\system32\winlogon.exe. status 0xc000000e.
the selected entry could not be loaded application missing or corrupt). I then tried to clone the larger drive again, error message NTLDR is missing. ct alt del went into loop.switched off pc refuses to boot now. please help. ps have only Vista upgrade disc would not use this for a repair. regards Aine
Thanks for reply. The main problem is,the PC will not boot, there are lights on the front of the case, light no 3 is on according to dell support, this could mean a possible processor failure? how this could occur with what was done internally, only replaced cables in original slots. Regards Aine
