saak Posted January 6, 2009 Report Share Posted January 6, 2009 A couple of days ago the ethernet connection dissapearedon my windows XP laptop, so I can not access the internet.When I type:>ipconfig /allWindows IP ConfigurationThe system gives me just this single line"Windows IP Configuration" and no any other information!The wireless does not work either.My other laptop XP works perfectly with the same ethernet connectionThank you Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted January 7, 2009 Report Share Posted January 7, 2009 It sounds like either the Operating System is messed up or the drivers for the Network Card(s) are. I lean toward a problem with the Operating System since all cards are affected.Do you have system restore enabled? Can you roll back to a configuration when everything worked using system restore? Quote Link to comment Share on other sites More sharing options...
