Guest PC Eejit Posted January 16, 2003 Report Share Posted January 16, 2003 I use a Philips Acoustic Edge soundcard.I right click the speaker icon in the taskbar.I choose "Adjust Audio Properties"I go to "Speaker Settings" and click "Advanced"I choose "5.1 Surround Sound Speakers" and click "Apply".The next time I start Windows XP - it's reset to "Desktop Stereo Speakers" :angry: :angry: :angry: I ask here for help...... :ph34r: Link to comment Share on other sites More sharing options...
Guest ellas Posted January 16, 2003 Report Share Posted January 16, 2003 have you got a control panel with your soundcard,if so see if changing it in there makes any difference. Link to comment Share on other sites More sharing options...
Guest PC Eejit Posted January 18, 2003 Report Share Posted January 18, 2003 Tried that - still the same :angry: Says "Desktop stereo speakers" now, even though I changed it this morning...... not to worry.Thanks anyway. :ph34r: Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted January 18, 2003 Report Share Posted January 18, 2003 I used to have similar problems with my Audigy card. It tended to happen when I had been playing certain games.I used to look in "Adjust Audio Properties" and it was set to stereo or headphones. I would set it back to 5.1 but there was no sound from my rear speakers... ;) Link to comment Share on other sites More sharing options...
